0 members (), 1,249 guests, and 44 robots.
Page 4 of 4 1 2 3 4
#151522 02/03/06 02:52 PM
in that last picture, is that a HOT wire spliced into a NEUTRAL wire? (black > white)
Cliff
#151523 02/03/06 07:47 PM
maybe it's a switchleg [Linked Image]
#151524 02/03/06 08:30 PM
Y
How common is the fused grounded conductor shown in the first picture?
In earliest times, grounded conductors were always fused wherever ungrounded conductors were fused. By 1922 (the oldest NEC in my possession), it was realized that this could cause major headaches in multiwire circuits, thus this practice was no longer required nor permitted. However, authorities were divided for many years thereafter over whether it was safer to fuse or not to fuse the grounded conductor of a two-wire circuit.
I have catalogs from the '30s that offer equipment in a choice of fused or solid neutral, depending on what your local inspector wanted. One 1936 catalog offers a "GROUNDED CIRCUIT PLUG-- Designed for permanently grounding neutral". It was to screw into an Edison-base fuseholder. (The professional alternative to pennies!) [Linked Image]
The company where I apprenticed had two old porcelain 3-pole 30A fuse blocks on display in the shop. Each had a piece of 1/2" all-thread soldered into the neutral fuseholder.
I think in some areas, neutrals were fused into the '40s. I've never seen this in work from the '50s.
[This message has been edited by yaktx (edited 02-03-2006).]
#151525 02/04/06 11:08 AM
Double-pole fusing was also used in Britain well into the 1930s, although I'm not certain the exact date that our IEE decided that it wasn't a good idea after all and specified that neutrals must not be fused.
#151526 02/04/06 03:13 PM
U
Paul, I seem to think it was the 1937 Supply Regs that changed the UK to single pole fusing - I need to check to be certain, but it was certainly around that time.
#151527 03/09/06 07:06 PM
Around my parts, those little ends are affectionately known as "monkey-faces".
Page 4 of 4 1 2 3 4
sbi
sbi
indiana
558,779 Are you busy
433,001 Re: Forum
402,021 Need opinion
