AE-Gifts, Affordable Everyday
0 members (), 270 guests, and 10 robots.
Page 3 of 4 1 2 3 4
#151512 02/23/05 08:44 PM
A little off topic, Harvey Hubbell received the patent for the pull chain type switched lampholder Aug 11, 1896.
#151513 04/20/05 11:43 AM
Not to be bothersome, but is that a broken knob in Pic #2?
Cliff
#151514 04/21/05 08:01 AM
Hi there Hemingray,
Welcome to ECN!. [Linked Image]
Looks only half broken to me. [Linked Image]
[This message has been edited by Trumpy (edited 04-21-2005).]
#151515 04/21/05 04:15 PM
lol, you're right. it IS half broken, the top half that is. [Linked Image]
[This message has been edited by Hemingray (edited 04-21-2005).]
Cliff
#151516 04/22/05 12:33 AM
Could someone explain american 'knot and tube' wiring to me? I see a lot of references to this in posts.
#151517 04/22/05 09:58 AM
"Knob & Tube" is the wiring method used (for the most part) in these photos. One of the older wiring methods, it was widely used from about 1919 until the late '50's.
In this method, the "hot" and "neutral" wires are strung separately along different framing members (appx a foot apart). Only at the device box do the two wires ever get close to each other.
When run parallel to the stud or joist, spliced, or changing direction, the wires are held in place by porcelain "knobs". When passing through, the wires are passed through porcelain "tubes." Likewise, when entering boxes, the wires are further protected by woven cloth tubes, called "looms."
#151518 04/22/05 06:23 PM
And if you watch old Tom & Jerry cartoons, you'll often see a depiction of K&T wiring on those scenes of Jerry's pad inside the walls...... [Linked Image]
#151519 04/22/05 08:09 PM
Paul, I haven't watched cartoons since I was knee-high to a grasshopper.....you've given me a reason to start again!
#151520 06/29/05 05:13 AM
We in Maine always called those transitions from BX to K&T "Endo's"
#151521 07/04/05 06:36 PM
K&T wiring also is a fairly good rat exterminator -- but does get the lights to dimming on their own a bit
Page 3 of 4 1 2 3 4
