0 members (), 1,308 guests, and 8 robots.
Page 3 of 5 1 2 3 4 5
#146478 01/09/07 06:23 AM
K
djk. The Triton people should be able to tell you if the ion exchange filter is necessary for your area.
#146479 01/19/07 09:33 AM
K
Paul
Did you ever resolve this problem?
Kenny
der Großvater
#146480 01/19/07 12:09 PM
pauluk Offline OP
Not yet, but the shower is used only rarely so we haven't rushed to do anything about it. I've not been able to track down replacement parts at a sensible price, so we'll just replace the whole unit.
I'm curious to investigate further though, so once the old shower is out I'm going to break open the canister for a closer inspection.
#146481 01/22/07 03:29 AM
Paul,
If it's not used that often.
Disconnect it, take it home and dismantle it.
It sounds like an Electrode Boiler unit that is all scaled up.
Scale will kill an Electrode Boiler, as in more resistance.
Hence cooler water.
Get Emery paper on the probes. [Linked Image]
#146482 01/22/07 06:47 AM
djk Offline
Scary South American approach to instantaneous electric showers:
Very safe use of wire nuts!
{ Images copied to ECN server }
[This message has been edited by pauluk (edited 01-23-2007).]
#146483 01/22/07 06:51 AM
djk Offline
They seem to be quite popular
#146484 01/22/07 10:11 AM
The last picture is clearly one of the "And I thought I've seen it all!" type! [Linked Image]
#146485 01/22/07 04:19 PM
Tex. Wait till you see the chemical WC full of battery acid! [Linked Image]
#146486 01/23/07 08:04 AM
pauluk Offline OP
I see one of those units is set to "Hot" -- In more ways than one! [Linked Image]
Here's another similar pic that I found some time ago. It was Central America -- Guatamala or Honduras if I recall correctly.
#146487 01/31/07 05:35 AM
K
DJK. O.M.G
