Well Ray,
200 watts !! Lamp or Heater
Now that you come to mention it, for an Electrician, I'm pretty slack as far as my own lighting needs at home go.
I've been here for like 12-13 years and although I've trebled the number of socket outlets in the place, I'm left with the original lighting fixtures in the place.
Most of them are them gaudy brass-looking fittings.
80% of my light fittings are wall-mounted, even when I moved in here, the lights in the kitchen were on the walls, I took them out and replaced them with a single 5ft fluoro over the sink.
Both the bedrooms have wall-lights and that is the reason for the 200W (2 x 100W lamps), because on the other side of the room, you can't see to read things.
This room that I'm using as my office, is a prime example, the original Architect couldn't have put the lights on the plans in a worse place.
One day I'll get around to installing some proper downlights and stuff.
But as my catch-phrase has become in the last few years, "It'll be a while".
Eh, Paul.
