Electricians revenge
0 members (), 205 guests, and 12 robots.
Google told me that there is a "Martin Lunel" enterprise producing electric equipment here:
http://office.tourismeguise.free.fr/pages/lunel.htm
There are some other hints to this connection and telling that ML produces sockets/plugs within Legrand but I did not find any related ML websites and I have no access to the French online catalogue.
Wholesale fittings stock Martin Lunel plugs and sockets, the catalogue shown at http://www.wf-online.com/lunel.html seems to have that exact socket on the front cover [Linked Image]
It looks like chipmunk has got the solution of your riddle. Nevertheless I'm curious and just would like to know whether the plugs are still produced and whether this is in France, as I thought after some internet surfing. I'd also like to know what they look like internally.
Interestingly, there is similar a system with regard to position of the contacts but probably built with a completely different philosophy: http://www.becma.ch/GB/index_gb.php?main=membres
This system is called "Marechal" and I remember that I had seen it in the Netherlands already.
Wolfgang
Welcome to the forum Chris.
As djk mentioned, the metal outer on the plugs here used a scraping Earth contact, if you were lucky puuling the plug out you would get a tingle in your hand.
If your hand happened to be damp, look out!.
What exactly was the problem with these? Was it just poor earth contact as the plug was being withdrawn with capacitive leakage giving a shock?
cdtidy Offline OP
Thanks for the welcome, Paul.
Here's a picture of the inside for those who are interested. You can see a pair of contacts at the "4 o'clock" position:
http://www.mythic-beasts.com/~cdt22/ml_socket_inside.jpg
I talked to WF Electrical today. Martin Lunel are based in France but aren't owned by Legrand. This exact socket is still in production, but is horrendously expensive. The rubber plugs alone are £39 + VAT! Consequently I think I'll have to find another solution. I'm now considering fitting the machine with brand new Legrand Hypra metal sockets instead. These sockets are cheaper than the Martin Lunel plugs(!) if I go for the regular range, or a bit more if I go for the "Prisinta" switched range. Probably I will go for the regular range.
By the way, I need some 30 A "Slydlok" fuse carriers for the same machine. Anyone know where to buy them?
Best wishes,
Chris
[This message has been edited by cdtidy (edited 10-24-2005).]
