0 members (), 1,247 guests, and 10 robots.
Paul, are the "mushroom" bulbs the ones that have the reflectorized surface inside and are used for flood-lights?
Those are the only mushroom-shaped lamps I've ever seen.
[Linked Image from tlc-direct.co.uk]
[This message has been edited by SvenNYC (edited 12-02-2004).]
U
Sven.
No, they are like the ordinary GLS lamp, but the top is slightly flattened. I suppose a similar shape to the R50, but not quite so long a 'neck', and they do not have a reflector. Not very descriptive - sorry!
They were very popular in the 60's and 70's, as Paul suggests, but they are now more a decorative issue. I'm not sure why they were 'favoured', but I recall seeing an adverrt for them years ago that said they gave out more light. Lord knows how!
uksparky,
Are you talking about the "Softline" range of bulbs?.
Made to be gentler on the eye, while working or not!. [Linked Image]
My favourite is Metal-Halide, to be honest.
The lower group of bulbs in this picture aren't quite the exact shape I remember, but about the closest I can find with a quick search. (The ones used in Britain more often had BC bases rather than ES, as you would expect.)
[Linked Image from img.alibaba.com]
[This message has been edited by pauluk (edited 12-06-2004).]
Thanks to John for the following pic:
Attached is a pic of the elusive "mushroom" along with a std GLS for comparison. Allegedly they give "more directional light"..
