0 members (), 501 guests, and 15 robots.
#139565 12/02/03 08:14 AM
In a way, I'm not sad that these appliances are too expensive to fix.
As Paul said above, the darn things are too hard to dis-assemble in the first place.
I know the feeling. So many modern appliances are so cheap and nasty to begin with, that working on them just doesn't have the same rewarding feeling as restoring a 40-year-old device to full operation.
#139566 12/02/03 03:18 PM
Trumpy Offline OP
There's just no way that a fine wooden cabinet can ever compare with a cheap, brittle plastic case, that is the hallmark of today's appliances. [Linked Image]
[This message has been edited by Trumpy (edited 12-02-2003).]
#139567 12/02/03 03:40 PM
Trumpy, that washing machine repairer sounds like he used to be a car mechanic. More specifically, a mechanic that works on car air conditioning :-)
Anyway, what I meant by "replace everything" is to buy a new unit and throw away the old one.
#139568 12/03/03 05:22 PM
djk Offline
I was extremely impressed with the servicablity of a new Miele washing machine I saw recently.
It is exceptionally well built and you can open the front panel on hinges to access the interior from the front and all of the parts are ultra high quality.
The digital control panel even has an IR port for uploading new software and fault diagnosis!
Very impressive peice of equipment in compairson to some of the cheap and nasty machines around.
#139569 12/03/03 06:15 PM
Trumpy Offline OP
djk,
Yes the use of lap-tops for appliance faults diagnosis is something that we have really got into over here.
Washing machines and refrigerators over here both have either an IR output or an RS-232 connection, to find out what's going on inside the machine. [Linked Image]
You mentioned the Miele brand, thier Vacuum cleaners are among the easiest to service, that I have ever encountered and they give really good suction too!. [Linked Image]
#139570 12/03/03 08:07 PM
djk Offline
There is a 30 year old Nilfisk still working perfectly here and it has been used pretty much every day since it was bought
[Linked Image from productiondesigner.farmfreshfilms.com]
750W
It was replaced with
[Linked Image from miele.ie]
1800W
Designs have definitely moved on!
[This message has been edited by djk (edited 12-03-2003).]
#139571 12/04/03 08:08 AM
I bet that new one won't last as long the old one!
I am alone in finding modern designs for appliances less than aesthetically appealing?
#139572 12/04/03 08:17 AM
djk Offline
I reckon the old one looked a lot better when it was brand new and shiney. It's been banged into just about everything it could be banged into over the years.
It has a weird connector btw looks like this / / on the side of the motor. The newer versions just have a 2 pin IEC connector, looks like a kettle lead without the earth pin.
#139573 12/04/03 10:45 AM
C-H Offline
I've seen that weird connector too on old vaccum cleaners. What is it for?
#139574 12/04/03 10:05 PM
djk Offline
in this case it was the connector for attaching the power cord [Linked Image]
I think in some old vacuums it may have been an outlet socket for supplying power to an add-on motorised brush.
