Oops, I think I should have written with the cover removed instead of without cover.
Trumpy is right: The B is just a looping terminal.
I went back to the manufacturer's website to check the schematics. There were a number of them, but this one is lacking. It seems I chose the wrong example...
Anyway, there are three terminals out at the top, marked with little arrows.
I think the N means that the switch to the left is single way, which means that the right switch is two way. There are different rocker plates (is that a suitable word for the 'buttons'?). Either you use two, like in the photo, or you use a single rocker plate. In the latter case, the switch will become double pole. If you want to use it as disconnect. Only then does the N(eutral) and L(ine) make sense.
Anyone else than me who wonders what will happen with the screws in all that water? Better use stainless...
