0 members (), 323 guests, and 47 robots.
#128830 02/03/04 07:52 PM
Randy Offline OP
does anyone know a better way to hook up 4 way switch circuits controlling a ceil fan and light seperately other than running parallel 14-3's to each switch ? I hope this makes sense..
#128831 02/03/04 08:20 PM
please elaborate
#128832 02/04/04 03:07 PM
It sounds like the question you are asking was discussed in this thread here . . .
https://www.electrical-contractor.net/ubb/Forum1/HTML/003829.html
#128833 02/04/04 08:15 PM
Randy Offline OP
here's the situation. I'm controlling a ceiling fan light from 3 locations and now the home owner wants all the lights and fans on different switches.I know I can double run the 14-3 to each location and do this , but is there a better more economical,less laborous way to accomplish this?
#128834 02/04/04 08:19 PM
Can you use a casablanca fan/light that has a frequency control http://www.casablancafanco.com/services/omans/instructions_it.pdf
I believe it is called the Inteli-Touch control
[This message has been edited by jeffrose (edited 02-04-2004).]
#128835 02/04/04 10:21 PM
As jeffrose mentioned, the option of using some types of Remote Control might be of assistance here.
Either Radio, Ir, or carrier current, this would eliminate additional cabling - but increase the costs and complexity of the switchloops.
X-10 equipment is one popular Carrier-Current method of control.
Scott35
#128836 02/05/04 09:37 PM
Scott,
Do you like the X-10 system? Icall it X-maybe, what about radio ra? But I think Randy was trying to keep it economical.
[This message has been edited by jeffrose (edited 02-05-2004).]
#128837 05/05/04 07:13 PM
I'm sure you offered this, Randy. If not it's a few months too late, but power to the fan/light and three remote controls are pretty easy on the labor.
Dave
#128838 05/05/04 07:15 PM
Battery-type remotes, that is...not hard wired.
Dave
#128839 05/23/04 01:04 AM
Besides X-10, you could also go with a Touchplate (despard ?) LV switch setup & remote relays near the load(s). Probably not the cheapest, but pretty easy to install.
Since this is long after you probably finished, tell us how you finally did it.
Radar
dsk 1
555,468 Are you busy
429,860 Re: Forum
399,484 Need opinion
