0 members (), 214 guests, and 12 robots.
#128702 10/17/03 02:18 PM
C-H Offline OP
This question had me thinking real hard before I figured out the answer. Let's see if someone else can figure it out.
What are 132 kV single phase lines used for? These are found in Europe, sometimes next to ordinary 3-phase HV lines, like 230 kV.
Workgear for Electricians
#128703 10/17/03 04:29 PM
Could it possibly be train supply lines (THIS IS ONLY A GUESS) [Linked Image]
[This message has been edited by james S (edited 10-17-2003).]
#128704 10/17/03 08:18 PM
Is this a trick question?
I would assume they are used for conducting electricity, otherwise why build them?
#128705 10/18/03 04:49 PM
As far as I know the Train thing is right. It's transformed down to 15 kV for Railways, frequency of 16 2/3 Hz.
#128706 10/19/03 09:14 AM
From www.electric-railways.co.uk :
The 15 kV a.c., 16 2/3 Hz, overhead system is used widely in Germany, Denmark and Austria. It is not used in the UK.
In Germany the 16 2/3 Hz electricity supply comes from railway generating stations. Power is transmitted at 110 kV via overhead lines. The power is transformed from 110 kV to 15 kV at railway substations that feed the railway overhead system.
#128707 10/19/03 10:46 AM
C-H Offline OP
James,
that was a quick answer. It is indeed the transmission for the train lines. Andy and Paul are right about the reason - the frequency is different from that of the ordinary power grid.
Paul UK,
I think your source is wrong. Denmark uses 50Hz, 25kV for the trains whereas Sweden and Norway use 16 2/3Hz, 15kV. This has forced trains that run between the countries to be dual voltage / dual frequency.
[This message has been edited by C-H (edited 10-19-2003).]
