0 members (), 181 guests, and 10 robots.
#127686 10/10/01 12:40 AM
Bill,
The round component in the center of the second drawing is an SBS [Silicon Bidirectional Switch]
This switch can control / pass AC, like the Triac does, except the Triac is a better amplifier for this type of job.
The SBS can be thought to be "madeup" of two SUS [Silicon Unidirectional Switch], in order to pass currents in both directions.
Similar to the way a Triac can be thought of as "madeup" of two SCR [Silicon Controlled Rectifier], in order to pass currents in both directions.
Scott SET
#127687 10/10/01 01:16 PM
Bill:
Don't let all the different terminology get too confusing. The SBS name Scott used is what I referred to as a diac. Just a different name.
An SCR (Silicon Controlled Rectifier) is also called a thyristor, a solid-state equivalent to the old thyratron vacuum tubes.
