Electricians revenge
1 members (winnie), 173 guests, and 9 robots.
#124710 12/02/06 08:28 PM
#124711 12/02/06 11:29 PM
Does anyone remember the colored "party" bulbs that had a magnet and a special filament that would wave around inside when lit? Haven't seen one of those in years...
#124712 12/03/06 12:49 AM
Yup. I remember those when I was a kid and was always curious as to how they worked.
Guess it just got too expensive to manufacture one of those vibrating filament things?
#124713 12/04/06 09:07 AM
Those bulbs had a small bar magnet in them, usually right above the seals. The 60Hz magnetic field in the filament reacted with the bar magnet, causing the filament to move.
#124714 12/04/06 12:12 PM
Sort of the same theory behind volt-meter mechanisms (D'Arsonval movements), huh? Neat.
Wonder how the filament survived without breaking.
#124715 12/06/06 08:16 AM
My daughter has a bulb like that in her room except the socket is a medium base. Got it at the dollar store!
#124716 12/09/06 03:41 PM
looks like the bulb from the dome light in that bus in the movie "priscilla queen of the desert" [Linked Image]
#124717 12/11/06 03:39 AM
Trumpy Offline OP
I've ordered and installed the "Fire-Glow" lamps before and they have a red colour to them.
They are nothing like this lamp however.
Which made me wonder about the three pin thing.
If a 25-40W bulb, needs 3 pins, is this to prevent a larger wattage bulb being fitted to the heater?.
I had a thread here years back, where a mate of mine that ran a restaurant at the time, had a heap of spot fittings in the windows and they were all 3-pin BC lampholders.
All 25 of them.
The last owner, took all the bulbs with them.
I hope they had fun getting them to fit thier lamps at home. [Linked Image]
#124718 12/11/06 11:40 AM
I'm sure you can just make them fit a normal lampholder by filing the third pip down?
That is if pips one and two are at their standard locations.
#124719 12/12/06 01:39 PM
The ones I'm referring to have the pins spaced evenly 120 degrees apart around the base.
