Bill,
Thanks for re-sizing my pictures!.
There's not many things more annoying than having to scroll sideways and up and down to see the whole picture.
Sparky,
I find the Dek-tite's really annoying to install, lots of rivets and RTV Silicone Sealant is used when I install one.
After installing the 12 in this job, I was just about seeing stars.
BTW, is there a similar thing on the market in other countries?.
We use these things for water-proofing protrusions through roofs and walls, what do you guys use?.
Gene,
Thanks for the compliment,
, mind you, I really hate seeing shoddy work, especially with exterior conduit, even though mine is up on the roof, that's no reason to do a messy job.
But, even though I was under a bit of pressure to get this job done before the kids started back at school,this is the result of sitting down for a few moments and just thinking about how the wiring/conduit is going to be done and what gear will be needed.
Paul,
I realise that you guys use PVC conduit in the UK, but do you guys still use Conduit wires inside them?.
The reason I ask this, is because, we gave up doing this a few years ago, apart from in Industrial installations.
In most cases, it's a lot easier to pull TPS through the conduits, before it's assembled, that's how I did this job.
Just means that you need a size larger than normal.
