Electricians revenge
1 members (Scott35), 159 guests, and 12 robots.
#123519 04/08/06 11:11 PM
Trumpy Offline OP
I'll let Les fill you folks in on what's going on here:
All yours Les. [Linked Image]
{Spelling error}
[This message has been edited by Trumpy (edited 04-08-2006).]
#123520 04/08/06 11:30 PM
LK Offline
When this was installed in 1937, they used 1 1/2" nips to connect from one box to another, back then they din't use bonding locknuts or bushings, so the entire system is all loose bonding, dependant on pipe and locknuts, i think we do a better job of bonding in todays installations.
#123521 04/09/06 05:36 AM
Great photo. I like the old meters and switchgear.
As per chatroom discussion 9th of April I hope you get the mystery 7 Amps sorted out, but I think you have it already under control Les.
Regards Ray
#123522 04/09/06 05:35 PM
Les,
What are the white cylinders at the top of the pic?
#123523 04/09/06 06:23 PM
Alan, you see an insulated pipe, probably a drain line, with the insulation interrupted by a hanger.
#123524 04/09/06 06:28 PM
I was thinking a steam pipe. [Linked Image]
I think that shows the difference between where Reno and I live.
New England vs the desert.
#123525 04/10/06 11:30 AM
I really enjoy looking at pix of old installations such as this. Things have come a long ways, with modern inventions such as wire gutters and circuit breakers [Linked Image].
I have a panel in my collection, very much like the first four shown on that long wall. The panel is typically sealed by the POCO, and inside there is a single 30 amp main fuse, an EXO switch, and also a small knife switch inside the box - I presume to shunt the meter out of the circuit for testing or replacement. The customer's fuses (all two of them) are in a little "appendage" on the bottom of the panel with a little door that swings up.
It would be interesting to know what is in the main disconnect switch [Linked Image].
Mike (mamils)
