#122054 09/20/05 06:04 PM
Roger Offline OP
This breaker was found in a mobile office trailer panel, it is a C-H BR common trip.
Roger
#122055 09/20/05 06:06 PM
Now there's something you don't see everyday!
#122056 09/20/05 06:26 PM
See I have this unusual 240 volt air conditioner, it draws 90 amps on one phase and only 30 amps on the other.
#122057 09/20/05 06:34 PM
#122058 09/20/05 09:10 PM
e57 Offline
Home made?????
I,,, I have never seen one of those.... Where does one get a new one? And what does one call it?
#122059 09/20/05 10:46 PM
looks rigged up. what was it running?
Cliff
#122060 09/20/05 10:52 PM
I couldn't have been rigged if it was just two single poles it wouldn't have the "common trip" on the 100 amp side and the case looks like one molded case not two seperate breakers. very unusual
#122061 09/20/05 11:48 PM
F
but one thing if that person look at the side of breaker and see the " rivet " like factory stamp type not like aftermarket stamp .
now that is very oddball something like this is very very rare to see it unless it was specal made for specal useage
Merci, Marc
#122062 09/21/05 06:08 AM
Roger Offline OP
The breaker had not been tampered with, it was the Main in the trailers load center.
It is obviously a manufacturers "ooops", probably made on a Monday morning or a Friday afternoon. [Linked Image]
Roger
#122063 09/21/05 10:57 AM
Cool
Looks like it has a few mile son it. So it has been working ok?
Maybe safe to assume it was 100 amps on each leg and the 35 just the wrong handle got assembled??????
Larry LeVoir
Inspector
City of Irvine, CA
