0 members (), 181 guests, and 10 robots.
#121272 07/06/05 11:44 AM
I've only been over to this location once in the last 5 or 6 years. But if I were able to frequent this location it would be fun to slowly and nonchalantly relocate loose items to the trash bin until the room was empty and clean.
Trumpy - this is a steel shed built on the roof. It was painted at one time. You can see our maintenance is top notch.
Radar
#121273 07/06/05 10:17 PM
Offhand, aside from the janatorial stuff, and associated crap, I don't see that much stuff that dosen't belong there at all..
I see air filters, and air ducts, and assuming that the filters are installed in that room, having a reasonable stock of replacements is not unreasonable.
Supplies for generator maintainance, such as oil, starting fluid, etc are also reasonable, as is a small amount of fuel.
I'm assuming the generator is diesel, with a small day tank, fed by a larger tank downstairs. This arrangement has been known to fail, so having a couple of jerrycans, and a hand pump available is a good idea in case you have to hand carry fuel up from downstairs.
Remember that in a situation where the generator is required to be running, you may not have the option of running out for supplies.
A good preventive maintainance program does wonders, but unless you exercise the generator regularly under full load, you can still have problems.
I would say that an appropriate storage cabinet would be in order, as would proper mounting for the fire extinguishers, but I wouldn't say that everything must go.
#121274 07/07/05 05:56 AM
I wonder who the genius was that decided it was a good idea to install water lines and a water heater in that kind of room?
#121275 07/07/05 05:57 PM
Hey, at least it's an electric water heater. By the way, geniuses (genii ??) abound around here. Really. No, really they do.
Radar
#121276 07/08/05 02:45 AM
I read somewhere that the American continent is sloped east to west. All the 'nuts' roll towards the Pacific. [Linked Image]
#121277 07/08/05 09:29 AM
I would be interested in knowing if there are any special safety considerations for this room since there is a HV oil disconnect switch in here.
#121278 07/08/05 05:53 PM
I can tell you that there are no special safety concerns for this room that are actually applied, hence the condition of the room.
And yes, we all walk with a bit of a port list.
Radar
(from the land of fruits & nuts)
