Electricians revenge
0 members (), 205 guests, and 12 robots.
#116511 04/08/04 03:32 PM
Randy, I think the t-slots were used for old types of plugs that are now obsolete. Some types had tandem slots, i.e. -- --, which were 120v, and some plugs had the NEMA 1-15 format used today. THey were combined to mke the T-slots so no matter what type of plug you had, you could use it in the outlet.
#116512 04/08/04 03:59 PM
Sparked.... So the T-slots were never actually used for 240V even though they showed a rating for it? [Linked Image] The -- -- Style plugs are NEMA 6-15 once you throw a ground pin in the works which is 240V.. I always thought thats where the different combinations originated, but there was nothing requiring the actual recept to only accept one or the other back then... NEMA was founded in 1926, some of the things I've come across that predate NEMA are really odd!, but they seem to accept both of those formats.. [Linked Image] Do you know what format they did use for 240V then?
Sven, the cap in the pic was orgiginal molded on... Youre right, the hole is where the former ground pin resided... LoL at the Home Desperate & Leave-it-0n... Everytime I try to use Leviton on a job, I either strip out a terminal screw or just snap the head off when tightening! My supply house carries P&S for the most part.. I stick with their BR-15/20 line or better.. Never had a problem... These also have the backwire where you tighten the screw to hold the wire. (not the "push & pray)
I used Arrow Hart for a while, just cause I thought they looked cool & they seemed to be built pretty well... Then Cooper bought em, 86'ed the line & stuck with the Eagle line.
If I do end up going to Home Desperate, I'll usually look for the Bryant "Tech-Spec"'s.. they are built well, but the depots around here don't really carry them anymore! I wonder if Leviton has something to do with that!
#116513 04/08/04 04:02 PM
Randy,
Okay, that makes sense now that I've looked at it again. At first look I thought that was a screw holding the two halves of the cordcap together. [Linked Image]
#116514 04/08/04 06:00 PM
At least the building had circuit breakers. If fuses the guy would just screw in a bigger fuse or a penny....
#116515 04/09/04 12:42 AM
wa2ise, Youre probably right... It took me about ½ hour to convince the restaurant owner he needed a dedicated circuit..(If my memory serves me correct, I think the equiptment spec'd this on the nameplate also) Not to mention a new cord-cap.. He just wanted me to replace the CB... (He didn't ask me for a larger size, I think he just thought it was bad!) Amprobe clamp-on showing 27 amps on the 20A circuit seemed to finally convince him.
-Randy
#116516 04/09/04 05:07 AM
That's what it looked like to me at first glance as well -- Maybe a very chewed-up Philips screw head!
I recall seeing an old movie (1940s) in which somebody takes a plug from a 120V appliance and we see him insert it into a receptacle on a box labeled 220V with the expected results.
Now, it's not exactly unknown for Hollywood to ignore technical facts for effect ( [Linked Image]), but I wondered at the time whether it was actually common for the same receptacles to be used on both voltages at one time.
