1 members (Scott35), 513 guests, and 18 robots.
#115144 08/19/03 07:29 PM
This transformer was marked that it needed 6" air space front and rear.
It is heavily loaded 24/7 and the top was to hot to touch.
It was pushed back tight to the wall.
Bob (iwire)
#115145 08/19/03 08:18 PM
Understand that {economy} dry-type transformers are often rated at 150°C rise—which means the hottest part of the transformer can run 270°F above room temperature at rated load. Hence, the logic behind the labeled clearance requirement.
#115146 08/19/03 08:41 PM
Did they at least offer you lunch?
[Linked Image from 65.108.216.53]
