0 members (), 355 guests, and 16 robots.
#112951 12/30/01 05:02 PM
[Linked Image from stanleyworks.com]
Looks like they (the wires) are inside?
#112952 12/30/01 06:39 PM
Joe,
"Looks like they (the wires) are inside?"
So what would your call be on allowing this switch 'in' a clothes closet?
You knew I had a reason for asking, right?
#112953 12/30/01 07:31 PM
Bill: I have no problem with this type of device and have also intalled many during my career.
#112954 12/31/01 08:51 AM
Ah, so you remove that shield from the front (prong side) to terminate the wires, right?
"Dead front" is like the U.S. plugs I have here where the wires are attached from the back ??
#112955 12/31/01 11:32 AM
Here is a dead front device.
#112956 12/31/01 02:47 PM
Bill, I think you'd like this place www.winchestermysteryhouse.com
I went there when I was about 10 yrs old
#112957 12/31/01 03:05 PM
Thanks for the pic Joe. That looks like the ones I have.
I guess that would make almost all of our plugs here the dead-front type, although there were some old 2-pin types made in the the past that were wired from the front.
I had some "DIY" closet light switches in this house when I moved into it. Someone had screwed microswitches (roller-arm type) to the door frames and glued thin stips of balsa wood around them to cover the live terminals!
[This message has been edited by pauluk (edited 12-31-2001).]
#112958 12/31/01 03:45 PM
electure,
That place sure sounds interesting! We'd probably have to get the Hardy Boys and Nancy Drew in on this one. [Linked Image]
Hey, I thought that Jimmy Stewart invented the Winchester? [Linked Image]
#112959 01/08/02 08:39 PM
I'm not sure that the different colorations are because of paint (alone). Could some of that be heat damage? I also note that the bulb is one of those tougher -and hotter- halogen types. Could the closed door contact the bulb? I think that heat, and not electric per se, is the main fire hazzard here.
Is this a rental? It almost looks like it was done by someone who didn't plan on staying for long.
#112960 01/09/02 10:17 AM
While on the subject. What about a switch-controlled receptacle mounted 80" high on the side wall of a pantry with a plug-in fluorescent mounted above the door?
