0 members (), 202 guests, and 16 robots.
#111865 03/13/07 10:49 PM
Trumpy Offline OP
Photo's and info submitted by Pappster855.
I shot this photo in another trailer park. The wire is actually 10-3 UF and the strap is the guy wire?
I also enjoy the strapping for the PVC along the side of the building. Good stuff!!!!
Thanks Ian. wink
#111866 03/14/07 02:16 PM
Wow. Thats pretty bad. I am not sure, but it seems to me like there could be a UV issue with that cable flown like that. That is the least of the problems, however. What is this feeding?
#111867 03/20/07 05:30 PM
A classic example of PVC conduit & NO expansion joints, and lack of strapage.
#111868 03/20/07 08:49 PM
Should we have been expecting PVC coated ridgid and XHHW conductors at a trailer park?
Peter
Peter
#111869 03/20/07 08:51 PM
LOL
#111870 03/20/07 10:32 PM
Don't think I.ve ever seen a service without even an attempt at a drip loop!
I used to work as an electrical inspector 20 years ago in NC. That looks like a service(?) I cited just before I left.
Trumpy Offline OP
Ahh,
Yes John, that is what is missing, I thought that looked pretty strange as I was editing the pics to be uploaded.
I also have certain misgivings about a cable being left to support it's own wieght where the end of it could be cut to bits on that pipe elbow.
If you were so slack here to use a length of Romex as an aerial cable (as in O/Head), you'd support it on a catenary wire at the very least.
Also very hard to see, but is there in fact any sealing in the end of that elbow?.
With regard to the PVC conduit work, I've done a LOT of this work in my time as an electrician and IMO if you can't be bothered to saddle it correctly, don't start the job in the first place.
This looks cheap and shoddy when it could have been nice and neat.
I would fail that job on sight without even leaving the work truck if I was inspecting it.
Next question would be, how does 2" rigid steel become 1 1/4 PVC?.
Assuming that the cable that enters the Rigid is the same as the one in the PVC.
because, you know, two-hole straps and those little plastic concrete anchors are just soooo dang expensive rolleyes
Mike (Trumpy)
Looking back, now I see the lack of a drip, and the lack of a suitable fitting.
Thinking (& looking) there looks like a cut off cable in the blue area & what may be an insulator on the wall. If that is so...
The 'mast' could have been a replacement for whatever was once at the blue wall area.
Whatever....IAN...what's the deal here??
