Electricians revenge
0 members (), 171 guests, and 31 robots.
#111374 11/21/06 10:18 PM
Ericksons are also called apprentice couplings to aren't they? [Linked Image]
"Sorry about digressing from the topic, couldn't resist" <Wont ever happen again!
Luke
[This message has been edited by Luketrician (edited 11-21-2006).]
Luke Clarke
Electrical Planner for TVA.
#111375 11/22/06 08:03 AM
I bet that if somebody had run electrical conduit right across the door which was needed to gain access to gas side of things, he'd be every name under the sun when the gas-fitter/plumber turned up. [Linked Image]
#111376 11/22/06 01:13 PM
Who wants to bet there's a picture of a generator with the electrical conduit run across it on a plumber or gas-fitter's Forum somewhere?
Ian A.
#111377 11/22/06 04:08 PM
Ian.....I think you are 100% correct. [Linked Image]
#111378 11/24/06 06:09 PM
Just an update, the gas to that gennie has not been toucched and I have a feeling it wont be. Figures though, I found out the gas fitter is a "buddy" of the H/O.. Ahh well at least my work passed!
#111379 11/27/06 09:52 PM
Have never worked with plumbing, so I don't know if there is a minimum height above grade, but couldn't they have run it closer to the ground, then put two 90's in (up, then over) to allow space? Maybe they just wanted to save on 90's...
