0 members (), 1,298 guests, and 13 robots.
#111235 10/12/06 08:27 PM
Z
An absurd installation, made hilarious by location!
#111236 10/19/06 04:19 PM
F
All i have to say here
QUOI ?????
that gotta be a good toe tripping spot
Merci , Marc
#111237 10/19/06 11:08 PM
#111238 10/25/06 11:26 AM
It almost looks like the concrete was done in more than one pour.
The backsides of both LB's seem to be in the same plane, and the concrete seems to change from gray to orange-ish at that point.
Look perpendicularly to the left of the larger LB, even with it's backside, and also parallel with, and about 2" to the right of, the smaller conduit.
Plus, that seems to explain why the LB's were not installed against the brick.
[This message has been edited by Larry Fine (edited 10-25-2006).]
Larry Fine
Fine Electric Co.
fineelectricco.com
#111239 10/25/06 11:43 AM
How slack is that?.
Marc,
How often do you walk into a corner of a building?. [Linked Image]
