Electricians revenge
1 members (Scott35), 36 guests, and 9 robots.
#110353 04/03/06 03:39 PM
"And as techie pointed out, after taking a closer look and blowing up that part of the picture, there are more than two wires in each nut. So it appears that two circuits are connected to one breaker. Red tag?"
Not necessarily. The worst that can happen is nuisance tripping, and that's only if the two wires' loads exceed the wire/breaker rating. This is no worse than the infamous home-inspectors' dreaded "double-tap."
Larry Fine
Fine Electric Co.
fineelectricco.com
#110354 04/03/06 05:01 PM
OK, regarding the use of another panelboard interior, let me ask about this stiuation;
At a local school here, there was once in service an old Frank Adam Fusible lighting panel - the kind with heavy duty tumbler switches next to each fuse. Come time to retire this venerable interior, the EC removed the interior and replaced it with a Square D QO style. The can for the Frank Adam was huge (compared to that required for a QO) so the only real modifications needed were to remove the FA door on the cover, mount the QO door over this existing cover (with no extra openings, actually a very good fit), and then install the QO interior in the proper place with some type of standoffs to bring the circuit breakers up to the usual position behind the cover. It turned out to be a much less traumatic event for the wires inside, with no conduit cutting and re-fitting needed, or extra J-boxes.
Going by the "letter of the law", I guess this would not be allowable, but does this type of thing happen anyway? With regard to safety, I would think that this is far safer than a fuse panel with an open socket or two, as was the case with the FA.
[This message has been edited by mamills (edited 04-03-2006).]
#110355 04/03/06 07:19 PM
The wirenutted circuit draws <10 Amps when in use.(This whole loadcenter is dedicated to one machine.) The alternative would be double lugging the breaker, which is definitely out.
An old Frank Adams box sounds like it would be a candidate for the same treatment.
[This message has been edited by electure (edited 04-03-2006).]
#110356 04/04/06 12:53 AM
What other option would be available when a panel is in a highrise apt. and mounted flush in poured concrete? But anyway for Challenger I would have at least used a Cuttler Hammer busbar and cover since it is the same thing with a different name on it.
#110357 04/04/06 07:33 AM
Challenger was not the same as a BR panel prior to Westinghouse buying Challenger.
