Electricians revenge
0 members (), 193 guests, and 13 robots.
Page 3 of 3 1 2 3
pauluk Offline OP
Welcome aboard Nick. [Linked Image]
I hadn't noticed it before, but you're right. If you look at the bottom of the last pic there is a lot of dirt there.
as some of you know here on the forum, nearly all of our work is related to the public house, nightclub and liesure industry.
personally i would not, or any of my crew, leave an installation in such a bad condition, temporary or not.
that is just not done, the lack of MCB blanks is one thing butjust the condition of the instalaltion raises more questions.
Pic # 2, appears to be a Wylex MCB board with maybe one 32A MCB and alot of lighting circuits connected, fed via what appears to be a bit of 10mm T/WE (twin and Earth similar to romex, the cable colours are the new harmonised type,
Is the BD staying or is it going, you could place all of those circuits on the main DB (the memsheild 2 board.
the SWA connected tot he Joint box, i would be worried about even opening that can of worms.!
pic # 3, the suspended RCD, well there aint a lot to say really about that one just, WHY??
pic # 5, the connection of cables to the lower TPN MCB, was the guy just lazy or does he like to test circuits energised by placing huis test equipment onto the exposed portion of the conductor entering the MCB ?
Earthing, this does not appear to be within code, 16mm tails incoming 10mm out, i dont think so!
main earth connection shall be the same diameter as the main supply feeds.
the thing in the US of `flying splices` well this just takes the biscuit, i would in no way shape or form leave this service enrgised in this condition.
temporary or not, it is just an absolute mess, especially as the property is occupied by customers and staff !!
frightening, very frightening .....
i hope that this instalaltion is going to re done soon, very soon..
Britspark
quote:
Do you mean that you don't actually have any houses wired for PME? (i.e. That the distribution lines are multiple-earthed, but that from the service drop onward it's effectively TN-S?)
Correct - we don't bother with PME over here, so you it's either a TN-S system in the urban areas or TT in the rural areas.
quote:
Also the amount of debris inside the disboard is unacceptable, should have been cleaned out before use.
All the debris had entered the board over the last few months while the roof was replaced - the board was apaprently live throughout the works! I don't even know if it was covered up. We cleared a load of dust out when we took the cover off.
For a TN-S system that would be acceptable.
Me too - my professional curiosity is getting the better of me, and I think an inspection is due. I will let you know how they are getting on.
Ian
Yeouch! That's bad! And to think I thought _my_ temp wiring was bad...
One thing to mention though...
You call that a lot of dust??? During construction works Austrian panels often have a full inch of debris at the bottom, especially the older fuse panels. Along with cigarette butts and other trash the electricians conveniently placed there. To be honest, the way most of my collegues smoke I'm always surprised when I open an old fuse panel and _don't_ find at least three cigarette butts in there.
Page 3 of 3 1 2 3
