107
13
Posts: 3,672 Likes: 5
Administrator Member
Posts: 5,485 Likes: 5
Owner won't fix?
Time for a new job. Time to call every AHJ you can think of...don't forget health dept and OSHA.
On the way out, disconnect everything. CYA
Pull the main disco and shut off the gas ,then run for it (just joking). I see a rusted gas pipe in pic #2,it may spring a leak at any time. If that thing leaks and get ignited by the wiring,it will be...pretty ugly. ![[Linked Image]](https://www.electrical-contractor.net/ubb/eek.gif)
Posts: 8,450 Likes: 4
Rust, rust, rust as far as the eye can see!. ![[Linked Image]](https://www.electrical-contractor.net/ubb/eek.gif) I know I'm going to get shot for saying this, but shouldn't chemically-resistant PVC be used in such a wet area? It has to be better than steel if it is just going to be eaten away. Or even use steel but treat it with a rust inhibitor before it is painted?. Glastron, what do you think should i turn him in for my own safety. I would say a definite YES to that question, this installation is in a dangerous state of repair. ![[Linked Image]](https://www.electrical-contractor.net/ubb/frown.gif) Any idea how old this installation is?. BTW, welcome to ECN!. ![[Linked Image]](https://www.electrical-contractor.net/ubb/wink.gif)
renovated in 97 no ventlation is the problem this is the second pool heater the wirenut mess and melted heater is on the whirlpool,wrong induction motor on the flue have had three bids at around 10,000 only thing you can use is conduit with two part epoxy paint.I'm gonna do something about this on monday maybe the whistle blower act will protect me ![[Linked Image]](https://www.electrical-contractor.net/ubb/smile.gif)
what's that meltdown in pic #4 ?
whirlpool heater wrong inducer blower in the flue heat coning down instead of out flue,flue is full of holes from rust anyway
Is this or these rooms used to store pool chemicals, i.e the oxidizer known as clorine? Or is the pool itself vented into the room. You say some are in the pool area! Any which way, its time to start over there. Coated steel, might help, PVC is still going to have problems too. But solution seems to remove source of corrosion from wiring, or vice versa.
The owner issue is a call to OSHA, or AHJ. I'm assuming this a hotel or the like? Its a puplic safety issue...
The Job on the other hand is expendable. If he wont fix this, it's just a waste of time to stay there wearing hand-cuffs.
Posts: 7,413 Likes: 10
Glastron & Gentlemen:
For what it's worth, this is one of the reasons the State of New Jersey instituted an "Annual POOL Inspection" about five or six years ago.
ALL commercial pools, meaning any pool other that a single family dwelling, MUST have an annual pool inspection. Permit required.
Attached to this law is a requirement for a Bonding & Grounding Certification, performed by a "Testing Lab" or a Lic. EC, stating that the bonding is within NEC requirements, and the grounding of all pool related equipment is intact.
A lot of people think it's a pain, but if it saves on life, or prevents one injury, it will be well worth the effort & costs.
BTW, as an AHJ, I can guarantee that the site in the pics would be shut-down immediatley. Repairs/replacement would be required by a Lic EC, and a permit & inspections/approvals before anyone used this pool.
