0 members (), 435 guests, and 12 robots.
#100850 01/11/07 11:35 PM
I'm supposed to be wiring up an above ground pool soon and looked at the job today. I noticed an existing, 120 volt landscape light that will be well within' 5 feet of the above ground pool. Does this light need to be removed once the pool is in place, or can I just install GFCI protection for it? I was looking at section 680.22 (B)(3) & (4) but the light fixture is less than 5' above the level of the pool water.
Thanks in advance [Linked Image]
Workgear for Electricians
#100851 01/12/07 12:24 AM
Looks to me like if this is a permanently installed pool the light has to go- 680.22(B)(3) On the other hand if it is a storable pool it's okay 680 Part III. Go figure.
George Little
