Like I said, a life of their own. This argument is becoming pretty arcane, and no longer makes much sense based on the original question. I'll go one more round.
A hot tub is a vessel in which on eimmerses ones body in water while potentially being exposed to electrical current under the worst of circumstances. A steam generator is a water heater, and it doesn't take much judgement to see the difference. If you want to spend the money on an unnecessary 2 pole GFCI circuit breaker nothing is stopping you from exceeding the minimum requirements of the code. But ask yourself, who are you protecting, and from what? A person in a steam shower is not in contact with the steam generator anymore than a person washing his hands at the sink is in contact with a regular water heater. A disconnect at the unit is also a matter of choice. A lockable circuit breaker is an acceptable disconnect for a water heater in a single family house. None of this applies if the manufacturer requires something different, but we are talking about satisfying the code.
This same discussion is going on in at least 3 different threads simultaneously. If you go look at the first one you will see that I stated the heater should be bonded just like a water heater.
