Is NM wire legal in a home through studs that may not be drywalled? Such as under a loft floor you can walk under? Years ago in Michigan, we used to run NM inside residential unattached garages inside the stud walls with no drywall going on them, and it was legal. They always passed inspection. (wonder if thats still legal?)
The Golden Rule - "The man with the gold makes the rule"
