A customer wants a light in her (large)pantry. Clearance is not an issue. There is a receptacle on the wall perpendicular to the door. The receptacle is tapped and a switch is installed on the wall to control a receptacle mounted above it at 80" (door height). A 2' fluorescent is mounted above the door and plugged into the receptacle, 8-10" away. Any problems?
