Rather than bundling I would consider that the violation is the NM cable supported by a run of PVC pipe.
NEC 334.15 Exposed work.
part (A) To follow Surface. Cable shall closely follow the surface of the building finish or of running boards.
The pipe is subject to being replaced or removed.
Alan--
Unless the fridge is used to do the laundry and not just keep the beer cold while doing the laundry it can NOT be on the dedicated laundry circuit.
[This message has been edited by Alan Nadon (edited 12-12-2006).]
Alan--
If it was easy, anyone could do it.
