Mark I think you and I are more alike than not. [Linked Image]
This is close to my Rubber maid cart.
[img]http://www.rcpworksmarter.com/rcp/ObjectServer?table=Images&id=13657[/img]
Mine has only one handle and it is on the side so a piece of plywood will lay on it as a plan table / bench.
(ECN Member 'CT-Wireman' kept trying to use it on the job, I told him to get his own. [Linked Image])
I also have a convertible cart ($59 HD) that I added an 1/4" plywood deck onto.
[Linked Image from homedepot.com]
I also use plastic bins as shown below for all sorts of things.
I like these with the attached lids, very compact when empty and you never lose the lid.
[Linked Image from plastic-shipping-containers.com]
John I depending on the work you do I think even pricey ones can be worth it.
It's hit or mis, my plastic cart may go months untouched than it's used daily for months.
The convertible two wheeler is used a lot, well worth the money.
