Regardless of the length of pull,
I'd recommend the prolific use of Lube.
Cable lube is a wholly under-stated thing, sure it will not help with sharp edges, but it will help with a long pull.
As an Electrician, I check all of the surfaces, (mainly bends) that I will be pulling through, for smoothness.
Anything that has a sharp or even coarse edge, gets the file treatment.
Having cables or wires blow out within a conduit, because of poor installation here is looked upon as very bad practice.
I expect it is the same in the US?.
