Wondering if anyone here has had an opportunity to try out this latest "ooh-ahhh-pretty" wiring device.
Legrand/P&S has come out with this receptacle where you pigtail a prewired plastic plug into the wallbox.
After everything is done, you just plug this connector into the back of the mating socket.
Somehow I keep thinking this method is just adding one more point where connections can loosen or rust and overheat.
The website does better justice at explaining it.
http://www.passandseymour.com/whatsnew/plugtail.html
