Welcome to ECN spark1051.
Where I live the inspector does require antishort bushings he checks for them. I think it is a good practice to use them anyway.
Then the question is there a local amendment that the inspector can cite?
Inspectors can not enforce the use of anti-short bushings with MC cable if there are no local amendments. The NEC does not have an anti short requirement for MC.
If you wanted to press the point you could print out the NEMA bulletin that Roger posted.
For what it's worth I use them too.
