0 members (),
96
guests, and
8
robots. |
Key:
Admin,
Global Mod,
Mod
pauls point about the ouyer layer of skin is well taken. I remember taking a course with Joe Tedesco about 15 years ago and we discussed an electrician being electrocuted by the filament of a broken temporary light. The energized filament punctured the skin on the back of his neck and killed him. To illustrate this, next time you have a minor cut, simply touch the probes of a DMM with your dry fingers then do the same with one finger and the wound. Compare the readings. You can also try comparing dry finger readings to that with a little bit of saliva on your fingers. Again, a dramatic decrease. Doing the math will show that you are much more likely to get to the 70-100 mA threshold of defibrillation through an open wound or while damp. Also remember that surface area plays a big role. The resistance from finger tip to finger tip is much higher than that from a the palm of your hand wrapped around a pipe, or your forearm tightly pressed against steel work.
Scott's point regarding wattage seems to more so addresses the "cooking" of internal organs, than heart and muscle spasm type electrocution effects.
[This message has been edited by Redsy (edited 04-17-2005).]
Entire Thread
Volts, Amps, & Ohms
aldav53
04/11/05 05:15 AM
Re: Volts, Amps, & Ohms
e57
04/11/05 06:50 AM
Gregtaylor
04/12/05 02:46 AM
Celtic
04/12/05 03:49 AM
wa2ise
04/12/05 09:57 PM
e57
04/12/05 10:58 PM
pauluk
04/13/05 12:39 PM
dereckbc
04/13/05 02:02 PM
aldav53
04/13/05 02:18 PM
GETELECTRIC
04/13/05 02:24 PM
aldav53
04/13/05 02:28 PM
aldav53
04/13/05 02:42 PM
Alan Belson
04/13/05 05:28 PM
GETELECTRIC
04/13/05 06:11 PM
Alan Belson
04/13/05 06:45 PM
GETELECTRIC
04/13/05 06:57 PM
wa2ise
04/13/05 08:08 PM
Celtic
04/13/05 08:16 PM
e57
04/14/05 12:33 AM
aldav53
04/14/05 04:38 AM
Scott35
04/14/05 07:33 AM
Alan Belson
04/14/05 09:28 AM
pauluk
04/14/05 05:14 PM
Alan Belson
04/14/05 09:56 PM
Dnkldorf
04/14/05 10:58 PM
redwyernut
04/17/05 09:09 AM
redwyernut
04/17/05 09:10 AM
iwire
04/17/05 11:00 AM
Alan Belson
04/17/05 12:13 PM
Redsy
04/17/05 01:01 PM
winnie
04/17/05 01:53 PM
mvpmaintman
04/17/05 03:28 PM
redwyernut
04/17/05 10:53 PM
iwire
04/17/05 11:02 PM
redwyernut
04/19/05 02:57 AM
e57
04/19/05 07:16 AM
redwyernut
04/19/05 09:49 AM
e57
04/19/05 09:58 PM
Scott35
04/20/05 01:07 AM
Alan Belson
04/20/05 07:30 AM
Alan Belson
04/20/05 11:04 AM
pauluk
04/20/05 12:23 PM
pauluk
04/20/05 12:25 PM
Bill Addiss
04/20/05 01:18 PM
Scott35
04/20/05 02:20 PM
Alan Belson
04/20/05 04:05 PM
e57
04/20/05 10:47 PM
