Must be the same bunch that travel the country! The other thing I see a lot is that many times only the inside of the box gets cut to and therefore the box sits behind the sheetrock instead of flush. If it's not caught before spackling and painting and then they are then cut properly the sheetrock doesn't go back without some more screws and then there's a whole lot of spot patching and painting to be done. Sure makes the Sparky look like the bad guy at trim-out time.
