rowdyrudy,
The Texas case did not involve the NEC. It was The Southern Building Code.
Veeck vs. Southern Bldg Code That is probably why more and more munis are enacting legislation declaring the NEC "advisory".
Then there is no code to enforce. You can itstall it anyway you like.
iwire,
That is true but the state and Federal laws are available on the net for free.
Not all of them are available on the net, at least in Illinois.
That said, unfortunately I think it is in-evadable that the NEC will be available to look at for free on the Internet.
When that happens there will no longer be a NEC, and maybe not even a NFPA. The profits from the sail of the NEC support most of the NFPA's other codes.
Don
[This message has been edited by resqcapt19 (edited 05-23-2004).]
