Every outlet I have seen has either rear entry tunnels with a screw to hold the cable or uses an insulation displacement method to hold the conductors. I have only seen one outlet that has stab-in connectors which was an Australian made 115 volt dual outlet (NEMA 5-15R pattern) made by HPM.
