Can you provide details of an "improved" connection?
-Conductor properties: material, size
-Terminal properties: material, plating, method of connection, temperature rating
-Pre inhibitor application data: resistance of connection, load current, voltage drop across connection, temperature rise of connection
-Post inhibitor application data: resistance of connection, load current, voltage drop across connection, temperature rise of connection, torque value used in termination
Also, mathematically how do you justify your statement of "...savings of 1-2% at each connection. When the TOTAL savings is read at the meter, we have, on an average, reduced electrical consumption by 20%..."? How can the total savings be larger than the sum of the parts?
