2 members (Scott35, HotLine1),
421
guests, and
23
robots. |
Key:
Admin,
Global Mod,
Mod
If I'm dealing with solid wire I just make a loop at the end of the (pre-stripped) wire....I usually use one of those screwdrivers with the little looping posts in the handle.
If it's stranded zip cord around the terminal screw of a lamp-holder or a plug, I strip a little bit more than necessary so I can grab the tip with my fingers and wrap around the terminal screw. After the screw is tightened I use the tiny side-cutters for trimming the excess.
Maybe I should start doing the same with solid wire...it seems easier.
I pretwist solids and solid/stranded even if it's two wires.
Stranded, I let the wirenut take care of it. Never had a tight-fitting nut come off -always give them a little tug after they're tightened...just to make sure.
Outlets are ground down - because a lot of the heavy duty cords I use have right-angle plugs that point ground down and the cord exits down also.
[This message has been edited by SvenNYC (edited 03-21-2003).]
Entire Thread
Pre-twist, Ground up, and...
Redsy
03/19/03 12:06 PM
Re: Pre-twist, Ground up, and...
txsparky
03/19/03 12:44 PM
Big A
03/19/03 12:45 PM
ElectricAL
03/19/03 01:46 PM
electrician02125
03/19/03 09:38 PM
sparky
03/19/03 09:58 PM
Fred
03/19/03 11:50 PM
HotLine1
03/20/03 01:28 AM
Electric Eagle
03/20/03 03:01 AM
arseegee
03/21/03 04:21 AM
Scott35
03/21/03 08:07 AM
Redsy
03/21/03 01:01 PM
SvenNYC
03/21/03 01:13 PM
Mvannevel
03/21/03 01:30 PM
GEO
03/21/03 01:53 PM
mickky
03/21/03 03:03 PM
SvenNYC
03/21/03 03:33 PM
