I came over to see the home my parents had purchased and the ouside receptacle looked burnt. I checked it out later and found that it had indeed been on fire. I looked around and noticed the patio light was wired in a unique way. I then noticed how insane everything in the patio was wired and turned off the power and ripped everything out. This 18g lamp cord run ran from a 15a receptacle, to the patio light, split at the junction with exposed wirenuts, then to a 20a recptacle, a 150w yard light, and another outside, 20a receptacle with each junction being by exposed wirenuts. Both receptacles had been burnt, the outside one had melted pretty severly.
I then did an exhaustive inspection of the rest of their home and found some equally dangerous firetraps. So, I get to rewire everything, because you wouldn't believe me if I told you the rest of what I found O.O
