I must have misunderstood the scale; it looked like the block of wood is more than 12" from the disconnect switch. That switch must be only 2" or so in height.
BTW, is that REALLY "supporting" the conduit or just propping it up so it doesn't rip out of the bottom of the enclosure by its own weight??
Tbe block of wood is more than 12" from the disconnect. I would say it's close to three feet below the disco. As far as the question of 'support' that's a good one. Is the conduit properly 'supported' or not, by code? I don't know. The weight of the conduit is borne by the wood, so I would say, 'yes, it is supported.' Whether it is supported in a code compliant way is a different matter.
