Hi Praveen,
If you have a compressor that was running under R12 Freon or even it's nasty cousin R14, there is no way that you can run it with newer gas.
The newer gas mixes R134 and R22 require additional oil that will burn out a compressor in a week or two if they are not designed for it.
There is no such thing as a "drop-in" gas between old refrigeration gear and new stuff.
As I said above, all the new stuff runs at appreciably higher pressures, you wil find that if R22 is put into a R12 system, the system will cycle on the High Pressure Overload, this will eventually kill the Compressor, due to the starting currents, if the start relay doesn't burn out first.
BTW, Welcome to ECN, mate!
