I imagine there will be someone with a battery powered converter. I ordered a coupon for one of the regular converters anyway, I figure it will run fine from an inverter but I will probably be opening it up to see if it doesn't run on one low voltage DC supply. It might be as simple as a 3 terminal regulator and a DC coax plug (maybe just the right battery).
