Jim,
This is exactly what I mean!.
I take it you wired all of them controls and relays?.
That is so well set out, I nearly cried, I've become so used to seeing rough, added on to work, (sure the original install might have been good, but when the next guy comes in and cuts all the cable supports, to get his gear in.....), it heartens me to think that there still is good neat work going on out there, hence the thread I hope to start.
All you other fella's reading this, needn't be shy at all.
Our Violations area here has a tonne of bad pics, lets see some of you guys best work, doesn't need to be directly electrical either, good conduit work would fly!
Bear in mind though, although a picture is worth a thousand words, a good description when posted helps a lot.
If anyone has a problem with getting pics uploaded or whatever, send me a PM, I'll get it sorted out.
