Between the PoCo drop, going into the weatherhead? Probably installed by a contractor, then.
I'm not sure we're looking at sun damage. I've seen many an instance of the colors fading, while the base plastic remained just fine.
Out here, there was a firm selling wire that was not UV resistant at all; the PoCo ran miles and miles of it. Now, the PoCo get to replace it all - and the maker is nowhere to be found. Here is a pic of the substandard wire:
![[Linked Image]](https://www.electrical-contractor.net/forum/RS/550R&B_Feeder_2cu.jpg)
I don't see that sort of 'alligator skin' damage to the insulation. Could the insulation have been damaged by something rubbing against it?
