There is a preview feature which seems to work pretty well. If you use that you can take all the time that you need.
I've lost too many posts to timeouts and back buttons to risk the preview button, Bill. This is really no different than hitting the "save" button in word while you're working on something. Only in this case, once you save it, you only have 5 minutes to finish what you're working on...
I favor unlimited edit time, but at the very least a wider window, 30 minutes to 1 hour. When has posting & editing ever been a problem here? The 5 minute edit window seems to be a draconian solution for a problem that doesn't exist.
