I have taken tests in several states. Have found that almost all are open book in a proctored room. Most do not allow code books that are highlighted. Some do not allow code books that are tabbed. None has allowed written notes in any reference book.
Have found that if you are prepared you will pass. The exception bieng those areas that have inspectors who do not want strangers in THIER area. Those are the ones that will not allow you to look at your test with an inspector if you choose to question the result.
The only one who need to cheat do not have the knowledge to be a licensed electrician or cannot take a test.
BTW the lowest score I have gotten was 79. Most were in the 90s.
Like the others here, if you prepare you will know enough to find the correct answer on just about any question. You do not need to cheat.
