Just to add to the neutral voltage thing. If you did not wire it you cannot guarantee that there is no voltage on the neutral. At the place I used to work at there was a 3 phase breaker that used 3 white wires for carrying the power. There was another time the guys were wiring up a welder. When Joe went to hook up the machine he found that the neutral had 70 volts on it.
Scott
