One other cause of short-cycling and no real cooling is a leak in the refrigerant lines. or a shortage of gas in the lines altogether. Until you get some gauges on the equipment, you have no idea what is happening inside the system. A set of Refrigeration Gauges is like our Volt-meter. And to a degree a Current meter too. System Pressure is a big part of Refrigeration.
